about door lining
LiteBulb
quick question, i found out that my door lining/rubber is out of position. i tried a little tugging to pull the strip out but i couldnt. was wondering if any of you can recommend me to a shop where they are willing to remove and reinstall is back (of course labour charge is assumed). need to get it fix quick because water is leaking in =(
Once you take out the lining (the one attached to the door I assume) its better to replace it with a new one. It cost RM220 each and labour of RM80 to install it. I did it with my mechanic in One Selayang, anyway the leak may also caused by internal lining inside the door card
