Will78
- Mar 2, 2011
- 67
My first BMW nightmare has begun... Recently I have experienced a "tuk tuk tuk tuk tuk" klonking sound coming from the front bonnet area (325i E90).The abnormal sound does not occur all the time and most often when I drive over very small bumps (like the yellow lines). The "tuk tuk tuk tuk tuk" will then last for a 5 to 10 seconds and stops again until another small bump.It sounds LIKE (but obviously not confirmed) a piece of hard rubber gone loose and knocking against plastic part of the car.The sound came only AFTER I jack up the car (hydraulic lift) to inspect the bottom of my car, although we did not touch, remove or add anything.I was told that this happens because when you lift up the car and drop it... sometimes, somethings can come loose.Sifus, what are your advice?
