318is G/box into 325 e36
ZeNeGeR said:
is all about Gear ratio. Jsen u will get low range power but not on high. Maybe at 5 gear 3krpm u car around 100kmh instead of 110kmh or even lower. u get close ratio that give u more torque, but not on high end. i got this concept from Mitshubishi engine. Not sure if it same as BMW correct me if i m wrong.
U are referring to the final drive ratio, not the gearbox ratio...
the 5th gear in the M50 manual gearbox whether Getrag or ZF is 1:1. Only difference is the first few gears. Another is that the 325 manual gearbox are made to endure higher torque as compared to the 318i gearbox. However, the gearbox can still be used on the 325i if u don't intend to drag the car all the time.
hi fabian...
isnt tat the gear ratios are the same be it 1st till 5th.. only tat the iS diff is different, reading at 3.15 n 325 is 3.45.. cox i went thru the service bentley service book... getrag tranny all has the same ratio.. although it didnt make sense n i was told it has a different ratios fo 1st till 3rd, but its stated there... im surprised when i went thru the book.. all ratios sama..
been sourcing out lately, even internet too has the same ratios... only the differential is different...
now im really confused...
My manual gbox is getrag, diff is lsd 3.15.
If i remember correctly, I test my speed 100kmh in 4th gear, i get abt 3.1K rpm.
So, i believe 4th gear is 1:1 ratio
jsen said:
hi fabian...
If u managed to find the gearbox ratio, then what's the confusion? Anyway, I was quoting from hearsay. Even if the first few gear ratios are different, it won't be a lot of difference..
And I would say the 5th gear ratio is 1:1 cos I have searched before and I have even tempted to swap to the E36 gearbox cos the 5th gear ratio for E30 is 0.81:1 (overdrive), and it can't harvest the torque like a 1.1 ratio would at 5th gear but too many things to do for the swap.
the only trouble for u now is the long shaft, u MIGHT need to custom cut and weld the 318i long shaft to fit into your 325i. That's when u might get drive train vibration. Unless u can source for a half shaft meant for the 325i manual.
jsen said:
hi fabian...
I have told you so.....only difference is the torque rating and that I have also told you what to look for in order to determine the torque rating :)
I dont think there will be any issues with the long shaft or drive shaft. Just replaced the diff. On the contrary, the iS subframe and driveshafts are different from the 325i. Well, that shouldnt be any issue as well. Basically its plug and play. :)
ok.. got the pics now.. thks again all...
albundy .. thks for the effort..
cheer.s
someone is selling his bmw e36 manual gearbox at lelong..woohoo:) .
dreammm.. dream dream dreammmm... dreamm... dream dream dream, n i want u, in my mind, n i need u.. u hold me tight whenver i want u, all i have to do, is dreammmm..
i can make u mine, taste yr lips of wine, everytime, nite or day...
only trouble is, cipek, its sure a pain in de ass..!
shit !!!!!!!!!!!!
bi bop ,bi bop , bi bop , bibop , ambulance !!!!!!!!!!
jsen is CRAZY already ,
lionel faster help himmmmmm
I have 2 stupid question...
1. if my e36 convert auto tranny to manual. How about the ECU it's need to be change too...
2. From what i know E36 have two ECU 1 ECU control engine & other one control gearbox it's true
my oto gearbox already terbabo..
-No need ....
-Yes ........Auto got another ecu ....If u convert to manual.....The ecu will remove 2gether wit auto GB .....
-Then just convert it ....
Hahahhahahh ....wait .....coming soon ......
lionel,
almost one month liao lor.. mana mana...
faster faster... :)
albundy,
dun have le.. now waiting lor for one from lionel.. hoepfully got le...
vcent,
will ya stop revving in front of me.. i put banana inside then u know.. celaka betul ni budak.. eveytime passed by me, must u rev it?.. working for shell ar?
jsen said:
lionel,
faster faster... :)
albundy,
vcent,
where got one mth ...only 3 week +6 days onli ......:D
Just call my fren up ......Tat guy now in Spore sourcing the gb for u .....:p
