1 pcs head lamp ned replace rosak angel eye?
dannisboo2001
Hi all memeber, My 1 pcs head lamp angel eye rosak...just 1 ring other stil gd condition. Can the 1 angel eye be fix? how many it cost? and the plastic head lamp also turn to blur and old..possible can change ?
dannisboo2001;402515 said:
Hi all memeber,
Bro, my opinions is, try to do DIY on your mulfunction angel eye, do observation
first before you made any changes;
1) Try to checks on the connection to the broken eye, may be got dry joint
or mis-contact issue at the connectors.
2) To be confirmed, try to do swapping in between the good eye and the bad eye,
just to ensure that your bad eye are really bad condition. Good luck.
*** To do as saids above, I assume that, you got the basic tools.
As you had mentioned for the blur head lamp, just do the cleaning and no need to
change it, provided the head lamp cover not serious bad condition and less stone
chips. Good luck. Thanks.
it happen to me last time.
just go to accessories shop n ask them to change the bulb.
but like azam said, check first before u go to next step :top:
HI Bro Azam,
Thx a lot ur suggestion, but for palstic head lamp how am i do the cleaning? coz the cover not simple cleaning can make the head lamp clear. any way i can do? maybe polish?
Once you get the headlight set out , it's relatively easy to open the cover .
There are 4 metal clips . Unclip them & pry the cover open .
You can use glass cleaner or polish to clean the cover .
P/S - Careful not to touch the metallic parts of the plastics lense casing
- it will oxidize easily . ask me how i know - he he he ..
But if the lenses are already in bad shape / pitted , it's of little or
no use . Get a recon set from chopshop - should set you back
about RM400 / pair .
Good luck !
Good luck !
Well said and such a good info, Bro megat... :top:
actually i wasted 1/2 a day doing that ...
i end up buying a recon set the next day
.. he he he ...:listen:
Kekekek... same goes to me, Bro megat... :wink:
Sometime itchy want to do DIY, end up got to buy new stuff,
but at least we've learnt something rather than do nothing... :listen:
