V-Man
Official Member
- Mar 21, 2006
- 1,726
- 63
As per title, here is the list:1) GM4 Autobox 6/10 - RM 13002) Drive/Prop/Long Shaft 8/10 - RM 10003) 97' Facelift Gear Shift + Selector + Base panel with S/W button (complete) 8/10 - RM 400 (BOOKED)4) 3.91 Ring Pinion gearing(no casing), for 188mm Mid Case 8/10 - RM 4005) Dual Mass flywheel 8.5inch/215mm(inner diameter) - RM 8006) M50/M52 Starter Motor from E46 8/10 - RM 3507) Original M52 Valve Head Plastic top cover(Written BMW) 8/10 - RM 2508) Original Door Steps - 8/10 - RM 1509) Front - Ohlins Hard/Soft adjustable 7/10 - RM 1200 9a **Have the rears as well but one of the hard soft selector is not functioning and both rears will require service, not sure if possible fix and where to fix. can be given FREE with no obligation if the front is purchased. But need to look for it.10) Royal Purple Synchromax Gear Oil unopen (2quarts left) 10/10 - RM70/quart - SOLD to PuddycatUpdate 09 March 201211) 3.15 Ring Pinion gearing(no casing), for 188mm Mid Case 9/10 - RM1000Thats all for now. Will add in if something pops up in my mind. Thank you.**If the price stated is not reasonable to you, tell me...price can bincang2 **
