Fadhlan
Official Member
- Aug 2, 2010
- 1,779
- 113
ARAGON 4004 MkII POWER AMPLIFIER
This one is a beauty. The magnificent Aragon 4004 power amplifier. In good condition. At 400 watts, this bad boy can run any demanding loudspeakers there is.
Aragon has produced a remarkable power amplifier...the 4004MKII. In addition to its sophisticated state of the art circuit topology, this amplifier fully embodies our philosophy of power supply design. The 200 watt per channel 4004MKII contains two separate mono amplifiers in a single chassis. A pair of high-efficiency, heavy duty torodial power transformers whose low hum fields, relatively light weight and compact dimensions make it possible to install this amplifier on a shelf adjacent to other components. Yet, it delivers all the power possible from a standard 15 amp AC line.
Power supply circuits and transformers influence sonic qualities by their ability to cope with the demands of the single handling circuitry. The dual mono configuration of Aragon stereo power amplifiers yield consistent separation throughout the audio frequency range, affecting the ability to produce a stable image independent of any power requirements or AC line conditions. Unlike almost all other amplifiers, Aragon doubles its 8 ohm power when driving a 4 ohm load, and the continuous output power continues to increase into 2 and 1 ohm loads. Hence, the model number 4004 is based on continuous watts per channel into 4 ohms.
Specifications
FREQUENCY RESPONSE 20Hz-20kHz
DESIGN Analog
POWER OUPUT 8 200-watts by 2-channels
POWER OUTPUT 4 400-watts by 2-channels
THD 0.05% for 8 ohm loads
S/N RATIO 110dB A Weighted
INPUT SENSITIVITY 150 mV for 1-watt output
INPUT IMPEDANCE 22 kohms
POWER CONSUMPTION 1500-watts max
This is a unit built in the US. Therefore this bad boy needs a Step Up/Down transformer for our 240V plugs. There is a slight buzzing sound from the left channel. Not noticeable when playing music or watching movies, only when the room is dead quiet.
Sold as is. Buyer pays for shipping. Cash on delivery in Kuala Lumpur. Brand new would be somewhere in the vicinity of RM6,500. This can be yours for RM2,200.
Specifications
DESIGN Analog
