[WTA] Tyre size
azeL_Inc
I have been searching around but cannot find thread that discuss about the tyre size that we can use.My question is, if i m using 205/55/16 now, can i use other size without doing any sort of modification?let say i want to use 255/55/16. Can i?Thanx in advance
u need to change the bigger width rim at least 8.5 inch and make sure your tire not gesek ur fender...tyre use 255x45x16
yup, if u really want 255, then u should use 45 profile instead of 55, if u use 55, your diameter % difference will be out by more than 8%. When changing tire sizes, we recommend staying within 3% of the diameter/height of the original tire. Any more than this and you face the risk of brake failure. http://www.1010tires.com/tiresizecalculator.asp
