world fastest bike
Johnny Ooi
ENGINE1. 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter); 525 lb.-ft. (712 Nm) @ 4200 rpm 2. 10-cylinder 90-degree V-type, liquid-cooled, 505 cubic inches (8277 cc)3. 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads4. Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6) 5. Two pushrod-actuated overhead valves per cylinder with roller-type hydraulic lifters6. Sequential, multi-port electronic fuel injection with individual runners7. Compression Ratio: 9.6:1 8. Max Engine Speed: 6000 rpm9. Fuel Requirement: Unleaded premium, 93 octane (R+M/2) 10. Oil System: Dry Sump; takes 8 quarts Mobil1 10W30 Synthetic11. Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan.12. Takes 11 quarts of antifreeze. 13. Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets SUSPENSION: Front:Outboard, single-sided parallel upper and lower control arms made from polished billet aluminum. Mounted via ball joint to aluminum steering uprights and hubs. Five degrees caster. Single, fully adjustable centrally located coil-over damper ( 2.25-inch coil with adjustable spring perch); pullrod and rocker-actuated mono linkage. Center-lock racing-style hubs. Rear:Hand-fabricated box-section steel inboard swing arms, incorporating "hydral-link" lockable recirculating hydraulic circuit parking stand. Single fully adjustable centrally located Koni coil-over damper ( 2.25-inch coil with adjustable spring perch); pushrod and rocker-actuated mono linkage. Center-lock racing-style hubs BRAKES: Front:20-inch perimeter-mounted drilled machined stainless steel rotors, one per wheel. Two four-piston fixed aluminum calipers per wheel (16 pistons total), custom designed. Blue anodized caliper finish. Hand-activated. Rear:20-inch perimeter-mounted drilled cast-iron rotors, one per wheel. One four-piston fixed aluminum caliper per wheel (8 pistons total), custom designed. Blue anodized caliper finish. Foot-activated. The Tomahawk is a Viper V-10 based motorcycle, a 500 horsepower engine with four wheels beneath it. Chrysler will be selling the original Tomahawk concept and nine replicas through Neiman Marcus, for up to $555,000 each. The motorcycles cannot be licensed, so they cannot be legally driven on public roads. A Chrysler spokesman told Reuters they were meant as rolling sculptures. Rumors had the Tomahawk selling for under $200,000, most likely at a loss or breakeven price, for publicity purposes - but still fully drivable. Wolfgang Bernhard, Chrysler's not particularly respected first mate, was said to be enthusiastic about that project, so much so that hundreds were projected to be built at under $200,000 each. They reportedly cost Chrysler over $100,000 to build (admittedly the work is outsourced). The Dodge Tomahawk can reach 60 miles an hour in about 2.5 seconds, and has a theoretical top speed of nearly 400 mph. Each pair of wheels is separated by a few inches and each wheel has an independent suspension. Bernhard said four wheels were necessary to handle the power from the engine. The Tomahawk remains on display at auto shows - though well out of reach of the general public, elevated on a special display. PERFORMANCE: 0-60 mph: 2.5 seconds (est.)Top Speed: 300+ mph (est.) DIMENSIONS: Length: 102 inchesWidth: 27.7 inchesHeight: 36.9 inchesWheelbase: 76 inchesSeat Height: 29 inchesWeight: 1,500 lbs.Track, Front: 8.75 inTrack, Rear: 10 inWeight Dist: 49F/51R Ground Clearance: 3 inFuel: 3.25 gallons ELECTRICAL SYSTEM: Alternator: 136-amp high-speedBattery : Leak-resistant, maintenance-free 600 CCALighting: Headlights consist of 12 five-watt LEDs, front, with beam-modifying optics and masked lenses. Eight LEDs, rear. Headlamps articulate with wheels. TRANSMISSION: Manual, foot-shifted two-speed Aluminum-cased two-speed, sequential racing-style with dog ring, straight-cut gearsGear Ratios: 1st 18:38; 2nd 23:25Clutch: Double-disc, dry-plate with organic friction materials, hand lever actuated with assist Final drive: Dual 110-link motorcycle-style chains Front Sprockets: 14 teethRear Sprockets: 35 teeth Longitudinal, centrally mounted engine, rear-wheel drive layout; monocoque construction, engine is central, stressed member. Body of billet aluminum.
if i recall correctly - it was done for a movie.....hollywood ones no less.
dun think this will go round bends very well....
Although very impressive, its NOT a motorcycle!
Defination:
A motorcycle (or motorbike) is a two-wheeled vehicle powered by an engine. The wheels are in-line, and at higher speed the motorcycle remains upright and stable by virtue of gyroscopic forces; at lower speeds continual readjustment of the steering by the rider gives stability. ...
or
"Every motor vehicle having a seat or saddle for the use of the rider and designed to travel on not more than three wheels in contact with the ground, but excluding a tractor."
This beast has FOUR wheels and the rider doesnt need to balance.
It cant bank, wonder how it takes corners.... would be interesting to burn rubber and power slide it thru though!
Anyway, whether it is defined as a bike or not, it looks wicked.... :eek:k:
World's fastest bike? What speed has it achieved so far? Probably less than 10km/hr since its a rolling sculpture :blink:
And who will buy it? Fuel tank capacity 3.2 gallons = 12 liters. Engine cc is 8277! How far could you go? :blink:
not sure what its called but there is another bike that more realistic.
US entertainer Jay Leno actually has one. It was also featured in the hollywood movie Biker Boyz.
A bike that actual has a helicoptor engine as an engine.
Performance Bikes Magazines has built a Suzuki Hayabusa GSX-1300R K5 with 700bhp from a turbocharged engine and it has done 242 MPH amd a 174 MPH wheelie... That has to be faster than the Dodge Tomahawk.
...maybe all life insurance agent avoid from dealing with this bikes owner... :D
