3 Series
E90, E91, E92, E93
wind noise from e90
<blockquote data-quote="rozaidi83" data-source="post: 26234" data-attributes="member: 23071"><p>hi guys,Would like to check if anyone have problem with a wind noise from the driver side window. normal drive at city area is fine but when you drive at highway speeds it almost sounds like the window is slightly open but it's close..hahaha... It's coming from the front door panel/window area. I have no idea if it's the window or door seal. OR it may just be the normal sound of the car. Or is't because i tinted the window? any input or idea about this? Thanks.</p></blockquote><p></p>
[QUOTE="rozaidi83, post: 26234, member: 23071"] hi guys,Would like to check if anyone have problem with a wind noise from the driver side window. normal drive at city area is fine but when you drive at highway speeds it almost sounds like the window is slightly open but it's close..hahaha... It's coming from the front door panel/window area. I have no idea if it's the window or door seal. OR it may just be the normal sound of the car. Or is't because i tinted the window? any input or idea about this? Thanks. [/QUOTE]
3 Series
E90, E91, E92, E93
wind noise from e90
