cloudbuster
- Jun 14, 2007
- 170
- 16
Hi Guy,My 1994 E32 740iL finally died on me today, luckily at home. As I was in a hurry, I just managed to check there is no voltage at the fuel pump, while the fuse 23 is ok (forgot to measure voltage here).Just going through the Bentley schematics now, it seems very likely that the power supply is from the X6400 B+ Junction Point to the K6300 Relay before going to the K6301 Relay and finally to the fuel pump via the F23 fuse.My question are: 1) Where is this X6400 B+ Junction located? 2) Did I miss any points of flow in the schematics?I will continue troubleshooting the fault this weekend and any additional information will be helpful. Worst case scenario may be jumping either relays or fuse 23 with a 12VDC tap from another point. Thanks....
