Daredevil;257066 said:There are 2 petrol stations next to EPF - Shell & BP. Naidu is behind Shell. The one nearer to the road leading in.
Jerman;257068 said:To be exact, coming from KL towards PJ along Federal Highway, turn off/left after the arch. KWSP building is on your left. Keep left and Naidu's is located behind Shell petrol station. His mobile 019-2110554
seech;258461 said:Thanks guys. So far A/C no problem but knowing bimmers it should just be a matter of time......
jarance;266896 said:really??? I have used my udm for about 10 yrs now.. never service or top up gas..
touch wood...
fabianyee;266899 said:Wah.. u never use your A/C for 10 years ah???
the A/C needs to be serviced as there sure will be dust getting circulated in the passenger cabin and blown thru the cooling coil and get accumulated and block the air flow...
The compressor also needs a bit of lubrication one..
touch wood...
jarance;266902 said:Everyday use air con lah.. Sometime too cold.. :stupid:
Only change the microfilter which by the way is installed in the wrong place cos it was designed for left hand drive.
BTW, change the microfilter when the airflow is low when at blower fan full speed.
Oil the blower fan motor bearing when the squeaking sound come.. All done BTW by DIY. :smokin:
Compare to local a/c when driving japanese car, use to top up gas every year.
Guess I am lucky... touch wood again...
rocksteady;266908 said:But now wife is complaining the AC is too cold... pulak....
BLaCkHoWLiNG;257099 said:wei...if everyone goes there... habis la... sure long que!
