When can get headlamp replacement glass for E36?
weechoon
Anyone know where can get headlamp replacement glass for E36? What is the price for original headlamp?
most BMW parts shop stock em. Make sure you get the Euro type with the dimples on the top side of each cover.
It will cost you, as seb said, RM400++, or about RM200-RM230/each. Make sure you also buy the rubber seal to avoid water vapor inside the cover.
These..glass replacements, are they easy to install DIY? :blush: \
thinking of changing mine too, since it's getting quite blurr
jeff.. easy.
You just need the right tools to remove the headlights. Besides that, tutup mata also can change. While doing that, I suggest you install the CCFLs if you don't have yet.
Originally posted by affan66@Jan 9 2006, 10:40 AM
jeff.. easy.
Just wanna change the glass, kereta dah ada tu" mata bidadari". :D
Originally posted by affan66@Jan 8 2006, 09:40 PM
jeff.. easy.
huh????racun pulak!!! :lol:
yeah jeff,may as well fit in the ccfl if ur gonna change ur lense..... :nyehehe:
hmmm. tricky.
The glass lens will come with the plastic surrounds. You need to transfer your CCFL mata bidadari to your new lens. You also need to cut up the inner glass lens and the rubber to mount the mata mata. You have to be super careful not to break or bend the mata bidadari as I am sure it is currently stuck to the current lens using epoxy or silicone.
