5 Series
E39
Vanos Failure
<blockquote data-quote="bimmer73" data-source="post: 446755" data-attributes="member: 1666"><p>Bro there is also a rattle kit for the vanos. If you change your vanos seals and there is a rattle then you need to change the rattle kit which is inside the vanos piston it self.</p></blockquote><p></p>
[QUOTE="bimmer73, post: 446755, member: 1666"] Bro there is also a rattle kit for the vanos. If you change your vanos seals and there is a rattle then you need to change the rattle kit which is inside the vanos piston it self. [/QUOTE]
5 Series
E39
Vanos Failure
