5 Series
UK Spec for Malaysia Driving Condition
<blockquote data-quote="ciklee" data-source="post: 24356" data-attributes="member: 22701"><p>Hi all,I need advise/help on what are things to modify/change on a UK spec E60 to suit our climate and fuel conditions.Introduction:I'm a student in the UK and planning to buy an E60 to bring home. Model-wise, I'm looking at either a 525i or 525d, which I think has adequate performance for my usage. Budget-wise, I can only afford early E60s circa 2004, which most probably has either M54B25 or M57D25 engine, respectively. Preferably an MSport model, although an SE would be fine as well.Question 1: What are the basic things to be done first? I'm planning to change/flush all the fluids i.e. engine oil, transmission, power steering, brake and coolant. Depending on condition, I may change engine mountings and suspension bushes too for a quieter and comfortable drive, as well as the auxiliary belts. Some suggested that I change the tyres as well since they might not be suitable for our weather. I also read somewhere in the forum that I should change the thermostat too. May I know why? How about the rubber hoses, do these need to be changed as well assuming there's no crack? I was thinking along the lines of rubber quality used for UK spec car might not be suitable for our weather, similar argument with the tyres. Are there anything else I might have missed? Question 2: Do I need to modify anything on the aircond system? Maybe bigger compressor, condenser? Do I need to replace the aircond gas or it is the same one used in Malaysia? How about the gas pressure/quantity used? I'm assuming since Malaysia is alot hotter, the car might need more gas compared to UK. No?Question 3: What do I need to modify to suit our lower fuel quality (both for petrol or diesel model)? I read somewhere that the car needs to be detuned? I wasn't sure what detune actually means in this case? Do i need to change the ignition timing and/or compression setting? Change injector? Remap ECU? There's also suggestion to remove the Diesel Particulate Filter (DPF) on the 525d because of excessive clogging caused by our diesel's higher sulphur content. What are the effects if i don't remove it? I thought the DPF can self-clean itself (catalyst regeneration) so why would it still get clogged?Question 4: What are other things to look out for? What is the minimum I-Drive software version should I get (or just upgrade to the latest one, whatever it is)? Can the leather material used for the seats survive the temperature or should I just settled for fabric instead?Question 5: What problem(s) specific to E60 (especially 525i/525d) should I look for when test driving? I've read that the active steering is a common problem. Anything else?Sorry, too many questions but I hope all sifus can help. i'm a total newbie with BMW (and diesel car), so wanted to make sure I have all angles covered before I actually go ahead and buy one. Also, please feel free to add other useful tips and tricks.Cheers!</p></blockquote><p></p>
[QUOTE="ciklee, post: 24356, member: 22701"] Hi all,I need advise/help on what are things to modify/change on a UK spec E60 to suit our climate and fuel conditions.Introduction:I'm a student in the UK and planning to buy an E60 to bring home. Model-wise, I'm looking at either a 525i or 525d, which I think has adequate performance for my usage. Budget-wise, I can only afford early E60s circa 2004, which most probably has either M54B25 or M57D25 engine, respectively. Preferably an MSport model, although an SE would be fine as well.Question 1: What are the basic things to be done first? I'm planning to change/flush all the fluids i.e. engine oil, transmission, power steering, brake and coolant. Depending on condition, I may change engine mountings and suspension bushes too for a quieter and comfortable drive, as well as the auxiliary belts. Some suggested that I change the tyres as well since they might not be suitable for our weather. I also read somewhere in the forum that I should change the thermostat too. May I know why? How about the rubber hoses, do these need to be changed as well assuming there's no crack? I was thinking along the lines of rubber quality used for UK spec car might not be suitable for our weather, similar argument with the tyres. Are there anything else I might have missed? Question 2: Do I need to modify anything on the aircond system? Maybe bigger compressor, condenser? Do I need to replace the aircond gas or it is the same one used in Malaysia? How about the gas pressure/quantity used? I'm assuming since Malaysia is alot hotter, the car might need more gas compared to UK. No?Question 3: What do I need to modify to suit our lower fuel quality (both for petrol or diesel model)? I read somewhere that the car needs to be detuned? I wasn't sure what detune actually means in this case? Do i need to change the ignition timing and/or compression setting? Change injector? Remap ECU? There's also suggestion to remove the Diesel Particulate Filter (DPF) on the 525d because of excessive clogging caused by our diesel's higher sulphur content. What are the effects if i don't remove it? I thought the DPF can self-clean itself (catalyst regeneration) so why would it still get clogged?Question 4: What are other things to look out for? What is the minimum I-Drive software version should I get (or just upgrade to the latest one, whatever it is)? Can the leather material used for the seats survive the temperature or should I just settled for fabric instead?Question 5: What problem(s) specific to E60 (especially 525i/525d) should I look for when test driving? I've read that the active steering is a common problem. Anything else?Sorry, too many questions but I hope all sifus can help. i'm a total newbie with BMW (and diesel car), so wanted to make sure I have all angles covered before I actually go ahead and buy one. Also, please feel free to add other useful tips and tricks.Cheers! [/QUOTE]
5 Series
