Squeaking sounds from rear
yolk
There's some squeaking sound coming from the rear shelf/part of the car. Sounds like when you have something in a polystyrene box and it rubs againt the box and you'll get a irritating squeaking sound. Suspect it's the rear speaker/board/shelf. Used to be when go over bumps/yellow lines can hear the rear shelf rattle but recently even on highway and got dips/uneveness on the road can hear the damn thing squeaking. How and where to check/fix it ah ? UDM pleasure being spoilt by this
Can the rear shelf/parcel/speaker board be removed ?? wouldn't want to break anything while trying to remove it ... :ph34r:
it can be removed and rewrapped. i've asked the upholstery shop in puchong before. around RM150 was the quote...
Magicfox
Ok thanks for the info .. will call you tomorrow to find out more :yes:
to remove the rear shelf, u have to remove the rear seats, speakers, belt covers.. quite easy if u have done it before.
regards.
I believe the problem already solved ..... :D
SO, now can enjoy ur ride.... B)
