BMW 5 Series Touch Screen
BMW touch style monitor method of new concept that changing interface concept that is existent outside device connection method newly.
No more using low resolution OEM monitor.
We were developed so that can use AV product that is circulated mostly for customer's desire repletion. Also, minimize that image noise and voice noise.
Because between interface and monitor and outside device is not existed and we developed as can select installation availability of outside device using OSD by user.
1. 800 *s 480 high resolutions 7 inches TFT LCD (LG Philips Original)
(LCD panel can be changed according to manufacturing company development process.)
When it’s connected to Car PC; 800*600 compression resolution supported.
2. CAN integration
- It’s can communication with the Vehicles system,
And it’s not breed problem in diagnostic and program.
The Rear view is appears when rear signal is using.
And it converted automatically when it’s no rear signal.
- If do not establish rear camera in OSD setting, vehicles OEM screen view is displayed.
- Can easily settled screen, image control, outside device selection, monitor part number input by OSD
- Can do screen conversion, OSD control, monitor part number input, PC control etc. by touch screen.
(Actually it dose not needed remote control.)
- Screen conversion enabled by menu button of I-Drive.
3. Front Screen Bezel
-It’s fully designed as like OEM Part and its meliorated touch feeling by haute SF coating material.
4. 100% Plug & Play
- Using Original LVDS & CAN connector.
- It’s can connector with Car PC by integration cable.
5. Integration Cables
- 1EA D_SUB (15Pin)
- 1EA 9pin cable (PC Touch wire)
- 3EA Video IN cable (Include 1EA rear input)
- 1EA S_VIDEO
- 1EA RGB
- 2EA Video OUT
- 1EA POWER Connector
6. Using Touch Panel
- Using NON CLEAR for make more less light reflection
- All the touch possibility products of touch panel application.
(EX : Navigation, DMB, DVB-T, Car-PC has touch program)
7. Easy Installation.
8. Clean image output of high resolution
