Harbinger
- Mar 23, 2006
- 11
HiHave been using Ecotint since 2004. Four years later, bubbles are forming between glass windows and film. It was a clean installation and no bubbles were found in the early years.Two window tints need to be changed. One is particularly bad with a diagonal streak across that makes it look like the glass is cracked (it isn't).Ecotint branch in Hartamas is quoting RM80 per window, which is too expensive. I won't pay more than RM50. RM30-RM40 is ideal range.So any recommendations on Ecotint or other films in PJ/KL is appreciated.what can be done by owner to minimise the film from detaching from window in years to come? The blazing tropical heat is unavoidable. Silicone spray will smoothen windows being wound up and down...would that also help somehow in minimising air bubbles?- ends -
