rear axle wobbling and shaking
rbojs123022
dear E36 Members,I'm a newbie, just joined today. Mine 328i appeared to be wobbling and shaking once it reaches 140 - 155 km/hr, but after 155km/hr the scenarios stooped even at 230 km/hr. suppose something wrong with the propellar shaft, coupling or driven shaft or it could be the suspension system. I've changed the suspension - koni brand 1 year ago. My car mileage is 131,000 km. Pls help me on this , Thanks...:eek:
rbojs123022;393654 said:
[SIZE="2"]dear E36 Members,
[/size]
I think you answered your own question already. Check the drive shaft, guibo and center mount. These are usually the culprits.
If your whole car is shaking I don't think it's your suspension setup.
Dear Vice President,
So sorry, overlooked, however, as for ur advised, noted and already done. Thank U.
[/SIZE]
Wow, you goes to 230km/h from 155km/h while the car was shaking! :eek:
that was too dangerous..and risky..., it could be the RIM was not in good round shape???
you said you were newbie of e36 328i...
had you check your 20pin ADS diagnosis socket 's bridge cap?
better check it before thing gone too late....
Read the post again... He explained that the vibration only occurs between 140-155kph...
Actually, I experienced this before... And after doing wheel balancing for all 4 wheels, the culprit was actually one of the rear wheels off-balance by just 5gram....
T.Q Guys, my special thanks goes to fabianyee, he knows exactly whats all about, anyway , others i thanked too. well, will do as advised. To Mr Joker, i don't quite understand d meaning of 20 pin bridge cap socket diagnosis, is it modic tools or something else ?
woobling and shaking
T.Q Guys and special thanks to Mr. Fabianyee, he knows exactly what's happening and others I thanked too. Well, will do as advised. By d way to Mr. Joker, I don't quite understand d meaning of 20 pin ADS Bridge cap socket ? is it Modic II or III or maybe something else ? Sorry, just to further clarify, Thanks.:rolleyes:
