Re-Wrapping E46 A-Pillar Fabric
morrogan
Official Member
Just want to share a bit on my experience on the above. I just done a re-wrap on my A-pillar.Procedures as follows:1. Ply open the centre cover strip with the original "airbag" word on it and expose 3 torx screws.2. Unlock all screws and ply open the whole plastic A-pillar panel.Apparently, the curtain airbag inflation route is not from the centre narrow plastic strip cover and I would guess that the whole plastic will break at the torx scres pivot point during emergency airbag inflation.Based on observation, the original plastic A-pillar panel together with the centre cover strip are first put on some gum and soak into some fabric dust (to give it a slightly spongily feel) and a layer of thin fabric is further laminated on it.In order to do a proper re-wrap using the similar to original thin fabric, one got to be very careful to use the appropriate gum. From my observation, most of the high viscosity gum will most probably penetrate the very thin fabric.If you use a UHU Stick type gum, it will do the job temporarily but the fabric will fall off fast.Another thing is that the replacement fabric got to have the appropriate thickness else the centre cover strip would not fit back.I enclosed a picture of the finished product using a thicker fabric. Also the fabric are wrap around (fold in) so that it will be more lasting. Trade off is the centre strip cannot be installed back and the torx screws will be exposed.It is not so easy as tot earlier......
Very nice and great write up :top: ... Mind telling us where you did the re-wrap or is it DIY?
I did it at Eurotuner, Kota Damansara. Please refer to Calvin in Vendor Zone.
Can you show the condition or the finishing work of the rewrap.
pss..sst how much is the damage?
This is the end product. Finishing is nice. Downside is there are 3 torx screws exposed. Well, it might become a fashion like the Levis Jean where buttons are regards as trendy.
morrogan, seems the fabric is too thick, on mine the torx screw cover is also rewrapped and reinstalled
Yes. Exactly. It is hard to find appropriate gum so that it won't penetrate the thinner fabric and the pillar will be sticky. Yours is nicely done....! Done in Penang? or DIY?
Done at a shop in Penang, thought of DIYing as well but left it to the professional in the end.
Thanks for the picture. May have to get use to the torx key
Today just got back my re-wrapped non-M-Sport steering. Very nice to touch and hold. Immediately my ride increased 5% in handling, phychologically.
morrogan
Mind to share where did you do this and how much? looks very nice
Done at Eurotuner @ Kota Damansara. Please refer to thread in Vendor Zone, boss is Calvin.
