shiva73
- Jan 31, 2007
- 1,179
Gents...E60-Yr 2004New problem for the past one month .When I put in/remove the key and the steering wheel column goes up/down, I've noticed from time to time it is starting to make a noise.This only happens while HOT climate and not while raining/cold weather . Does any aspect of this movement need to be greased and if so where? Is this something to do with steering colum? BTW , i also noticed once , the steering didnt return upward - i adjust it manually up and down and then it work fine . It look like my wallet going to robek again . Appreciate your advice.TQVM
