mini_jeff67
- Dec 14, 2004
- 2,017
Got this in an email, so thought should share this here. Just add on as we go along, for the well-being of all members and people we know.This actually happened to a Man not a woman recently in KL.Imagine: You walk across the parking lot, unlock your car and get inside. Then you lock the doors, start the engine and shift to Reverse. Then you look into yhe rear mirror to back out and you notice a piece of paper stuck to the middle of the rear window screen that is obstructing your view. So you shift the gear to Park, unlock your door and jump out to remove that silly piece of paper (or whatever it may be) When you reach the back of your car, that is when the surprise begins! The Car-Jacker appears out of nowhere, jumps into your car and takes off!! Your engine is still running, your belongings are all in the car, including whatever you may have bought from you shopping trip. They will mow you down as they take off if you so much as try to stop them.BE AWARE OF THIS NEW SCHEME THAT IS NOW BEING USED.Just drive away and remove the paper that is stuck to you rear window LATER, and be thankful that you read this email. I hope you will forward this to your friends and family members. Imagine if your purse is inside the car. They then will have your IC, credit cards, home address and maybe your house keys!
