7 Series
Once again a Bimmer believer!
<blockquote data-quote="vjayprakash" data-source="post: 380218" data-attributes="member: 1305"><p>Hi Mark 728i E38 is a good model expecially if its a later version 1999 onwards.</p><p>I've owned a 1997 model single vanos and it was a great model. Parts can be a little </p><p>higher compared to E36 328i. Before getting one check records if parts replaced are original, some non OEM parts are not compatible to the cars wear & tear results in poor handling. Good Luck</p></blockquote><p></p>
[QUOTE="vjayprakash, post: 380218, member: 1305"] Hi Mark 728i E38 is a good model expecially if its a later version 1999 onwards. I've owned a 1997 model single vanos and it was a great model. Parts can be a little higher compared to E36 328i. Before getting one check records if parts replaced are original, some non OEM parts are not compatible to the cars wear & tear results in poor handling. Good Luck [/QUOTE]
7 Series
