ausserdem
- Nov 27, 2007
- 60
Totally confused with wheel offset.There are plenty of pages on the web which let you calculate the wheel offset, but none actually tells you what offset you can take take. For example this website: http://www.gruppeb.com/BMWwheels/fitments/It says: H = HIGH Positive Offset - E36, E46, Z3 & X5 Models - Typically +46, 40, 38 & 35 mm Offsets *What does it mean? Can a E36 takes all wheel offset from 46mm to 35mm?My original rim is 16 X 7 Offset 46mm. Can I fix a wheel 17 X 7 Offset 37mm?
