Need help, vibrating engine M43.
Blue_toyz
Dear all member,I have problem on my engine m43.engine vibrate and bad smell coming out from exhaust.just change new Idle valve, new MAF and new Spark Plug but the problem still same.I check my spark plug but find oil at my spark plug.Anybody have experience on this problem?Thank you.
Best to take it into a reputable workshop and get it checked out. Rattlings could be caused by a few things from bushings, mountings, o2sensors, crankshaft sensors etc etc in which those are easy and relatively not costly to replace comparatively to an engine overhaul.
Check the HT cable. One of the spark plug is misfiring.
The spark plug that has oil is most likely the culprit.
