need help, engine stop while running half hour
saiful jamal
hi,my car e46 year 2002. engine mati bila jalan lbih kurang 20-30 min.tak boleh start and after tunggu bagi engine sejuk my car can start back . tapi x boleh jalan lama 20 min dia stop .temp ok, alarm xde kluar ape2.need advice knp bile engine tu dh sejuk skit dia boleh start balik tp jalan x lama mati balik . baru terjadi semalam.
saiful jamal;826466 said:
ok , but why the engine cold that car can start , it due the cam shaft intermitten mulfunction.
When camshaft sensor kaput, that is the symptom.
VP Herbert is very accurate, this is the symptom of these hall sensors failing. Change all three as a preventive measure (cams and crank sensor). Home diagnose can pinpoint to which sensor that is failing. Sensor replacement can be DIYed. Cheers
audil,
can you suggest how to DIY to replace thus sensor , is't difficult or not , how much this sensor?
