my obc shows coolant low...
yat325
guys this morning my obc shows my coolant low.......wat realy it means??? coz i check my radiator sparetank its ok......i wait like 6 to 8 hours not start the engine n open the spare tank cover n see the water lavel is below the minimum line,but after i release the presure cap the water start fulling the spare tank more than the minimum line..pelik bin ajaib...or the sensor jahanam.....plz advise....tq
its a symptom to....... brake your wallet again.. haha.. i believe he mention the expansion tank. your coolant sensor look like working. base my experience handling m50 engine.. it have aging cooling system.. if u never check or done A-Z replacement on it, its time for you now. and check the bubble- save your engine then
Had the same problem, replaced he coolant sensor. Problem fixed.
hi bro... i did the faster way... i tap both wires together... hehehhehe but its for temporary only so you wont see the irritating warning
wah can ahh...heheheheh tanx for sharing...by the way the prob solve oridi.....the soket loose.....
yat..thanks for the information..
