Hi guys i just brought my fog lamp from Yanz Used Part. So now the problem is i cant turn on my fog lamp. I just plug and play to my car. But there is no light on my fog lamp. So i try to plug my fog lamp to the low beam connector to test is it working or not. But its work no problem with the fog lamp. So now I DIY it by connect it to the low beam connector. 1 lamp are ok but the other are not ok. So that I might gonna check it later. What should I check if i want to use the Fog Lamp switch and not direct connect to low beam connector?
