BMW Tech and Performance
Engine Tech
M54B25 engine swap
<blockquote data-quote="gendong" data-source="post: 757226" data-attributes="member: 22402"><p>Used engine price is about there. If you are getting it from a chopshop, make sure they provide some kind of warranty. Do bear in mind, since the engine is out of the car, you might want to refresh its seals, gaskets etc. additional cost.</p><p></p><p>Yes, by right you will need to register the new engine. If the purchase of the engine is proper, you’ll be provided with the necessary customs forms by the seller for registration purposes. Complete the necessary documents, check at Puspakom once approved, JPJ will endorse.</p><p></p><p>Yes you can sell the shell of the car. Normally it’ll be sold as project parts.</p></blockquote><p></p>
[QUOTE="gendong, post: 757226, member: 22402"] Used engine price is about there. If you are getting it from a chopshop, make sure they provide some kind of warranty. Do bear in mind, since the engine is out of the car, you might want to refresh its seals, gaskets etc. additional cost. Yes, by right you will need to register the new engine. If the purchase of the engine is proper, you’ll be provided with the necessary customs forms by the seller for registration purposes. Complete the necessary documents, check at Puspakom once approved, JPJ will endorse. Yes you can sell the shell of the car. Normally it’ll be sold as project parts. [/QUOTE]
Engine Tech
M54B25 engine swap
