M52B28 's Actual POWER
Status
Not open for further replies.
JOKER
Banned
The actual HORSE POWER for M52B28 in N.A modecan reach high as 280bhp +/-, equavalent or near M3 rate.:love:release such horsepower without alter the size of engine., engine size remain in 2.8Litre::love:First: change the OBDII system to OBD1 system (full exhaust system, DME, wiring,software) unlock additional 25bhp+/- :top:Second:change the M52B28 OBDII manifold to M50B25 OBD1 manifoldwith the conversion kit. unlock additional 25bhp+/- :top:Third:Install aFe performanch Cold air intake system. unlock additional 25bhp+/- :top:Fourth:Replace the Pulley system to TMS Underdrive power pulley system and steward high-performanch water pump to reduce auxiliary drag, unlock additional 15bhp+/-the horse power will be near or equavalent to:e36 s50b30 M3 (stock), mitshubishi EVO 1-7(stock), Mazda Rx-7 (stock)manual gearbox sure :top:, but with autogear the car need to reduce the weight to optimal, not too heavy and not too lightweight.
You've been seeing too many "Guaranteed 25HP gains!!" ads.
for those who mod with OBDII system will not fell any power gain.
it need to be mod with OBDI system, with MS41.0 DME,
if your car too heavy (1500KG+/-), it also will not fell any increament.
or maybe your M52B28 's internal was actually just 2.0L only?,
because the engine can be same, but internal part was interchangeable
don't look down on plenty 10-25 horse power,
single biological HORSE can tow a few hundred KG of LOAD,
imagine 10 Horse or more....
internal engine mod with
TURBOCHARGE or SUPERCHARGE will be far superior,
but it require more component and cooling, more weight,
if the car too heavy or too powerful, it will just slippage over the clutch,
overpower the gearbox...exceed the torque limit...
JOKER;430782 said:
Fourth:
:76:
:34:
Please go to sleep
:rolleyes:
sure do.
I am pretty sure your car have "ID ten T" issue too.
Status
