Originally posted by dvng@Dec 17 2004, 04:56 AM i think the m20 run on 17lbs and the m50 injectors are rate 19lbs+. If i'm not wrong, you need to get the correct flow injectors or you will run the risk smashing your pistons into the blocks. You also need the ones which are numbered 415 and which are 19lbs. The 41 comes in a 16-range from 16lbs to 24lbs and different colours. You need the correct ones, ithink 3 out of the 16 and green in colour. Apparently the correct ones comes from the e36 m3. Alternatively u can use the Accel injectors rated 19lbs by eurocarmotorsport.
Aiyo, DVNG..dun scare TOM away lar...using bigger injectors wont smash the pistons into pieces, revving your stock engine to 7200rpm will!!! I have tried 24lb injectors before, massive torque!!Tom, get the M50 B25 injectors. Then just check whether you are running too rich or not.Another thing most people tend to forget or dunno, cars with richer settings tend to last longer because the petrol actually cools down the engine!!
