-- How many Litres does the tranny makes. (You have mentioned 8L, but I saw 4L on the following Japanese site:
http://images.google.co.uk/imgres?i...tbnw=108&prev=/images?q=jatco+corp&um=1&hl=en
the tranny takes about 7-8 litres
-- When I drained the tranny, only about 3 or 4Litres came out. Is this correct or there is something that I am wrong
the tranny oil pan holds about 4 litres of fluid, the remainder of it is stuck in the torque converter, for a complete oil change, you will have to remove the torque converter unit to drain the fluid. there will be some fluid stuck in the transmission oil cooler too, just unbolt and drain the unit.
-- How do you re-fill the transmission with the fill hole on facing downwards. Please make me through the whole procedure from start to end.
with your car raised. you fill the tranny using a hand held hydraulic pump. fill it until it starts to drip from the hole. start the engine and cycle through p-r-n-d-4-3-2-1 and off the engine, this will run the fluid through its internal and into the torque converter. continue filling until it starts to drip again. plugged the filling hole, start the engine and clcye through the gears again and let it idle to its operating temperature. open the fill hole and continue filling til its full.
-- And how do I check if the transmission is full with 8Litres
keeping track of the number of bottles used would be a good start.
