Just wandering if you guys service the car, the amount of oil replaced is either 6.5L or 7L or 7.5L on the M50 series engines ?mine is 6.8L... plus oil filter on my M50 :wink:wonder on the M50's, M52's and M54's ?
yeah....you ask a technical question aand i reply in a technical way,especially the last 3 words....silly cat:stupid:
so basically if the engine is filled from an overhaul, it should be more, coz no oil inside and has to be filled a few times to get the optimum fill, my guess 7.9l in total .
if a normal oil change then it should be between 6.5l to 7l , again depends on the time of day, viscosity of the oil, heat within the engine, etc,etc,etc
just get extra oil and keep, who knows you can find ways to make use of it......especially read the my last post ,the last 3 words.....:rock:
pussy bro - you know my car - also 6.8L plus oil filter...:top:
too much oil - un-necessary preassure in your sump at higher speeds... unless u put a oil catch tank... but then again - you're the expert!:rock: :rock:
You are most welcomed :rock: ......and thanks to you for your business, not many bmw drivers are willing to spend rm100 per hour for consultation fees....:top:
......if a normal oil change then it should be between 6.5l to 7l , again depends on the time of day, viscosity of the oil, heat within the engine, etc,etc,etc .....:rock:
reddybaron.....i read somewhere, as the engine approaches the speed of light, u dun need much oil. maybe some chunni oil is enuf....pussy's engine should be aroudn there la...
