3 Series
E46
Is Engine Oil Leak a common Problem for e46?
<blockquote data-quote="ivanblur" data-source="post: 25868" data-attributes="member: 22304"><p>Hi all sifus, friends and bimmer loversJust one Q to ask here: Is Oil Leak a common problem for E46? I ve this issue recently with my E46 318i Yr 2004 and I ve change all the seals but seems the leak is still there, NOT the severe leak that creates a pool of oil but those tiny ones that sekejap ade sekejap takde. Took to the mechanic after checking he also cannot find the leak source. Any bros experience this issue? BTW the color of the oil stain is brownish gold color and biggest possibility is the engine oil. All seals changed including the oil sum gasket and the valve cover gasket....Hope to hear some sharing...Thanking you all in advance</p></blockquote><p></p>
[QUOTE="ivanblur, post: 25868, member: 22304"] Hi all sifus, friends and bimmer loversJust one Q to ask here: Is Oil Leak a common problem for E46? I ve this issue recently with my E46 318i Yr 2004 and I ve change all the seals but seems the leak is still there, NOT the severe leak that creates a pool of oil but those tiny ones that sekejap ade sekejap takde. Took to the mechanic after checking he also cannot find the leak source. Any bros experience this issue? BTW the color of the oil stain is brownish gold color and biggest possibility is the engine oil. All seals changed including the oil sum gasket and the valve cover gasket....Hope to hear some sharing...Thanking you all in advance [/QUOTE]
3 Series
E46
