the locknuts are all standard size for all BMW... it's the pattern which is different. if all the same then I get 1 key can steal all the rims liao loh.....
The lock nuts are not standard across all BMW. If you buy a set of lock nuts, the label will specify the type, usually "Type XX". So you must find someone with the same lock nut pattern as your car - good luck!!!
