3 Series
E46
humming noise from rear wheel
<blockquote data-quote="tropos_net" data-source="post: 598939" data-attributes="member: 2595"><p>the rear differential needs lubrication for the crown wheel and pinion shaft inside. this one needs to be replenished. is good idea to replace with new lubricant (hypoid) plus with some liqui moly friction modifier. so the whining will be reduced.</p></blockquote><p></p>
[QUOTE="tropos_net, post: 598939, member: 2595"] the rear differential needs lubrication for the crown wheel and pinion shaft inside. this one needs to be replenished. is good idea to replace with new lubricant (hypoid) plus with some liqui moly friction modifier. so the whining will be reduced. [/QUOTE]
3 Series
E46
