Today i change my E60 530D Sport rims & tires..!!Now the warning lights keep bugging me on the I-Drive screen..??Anyone can help & teach me how to reset...???Thanks in Advance...:rock::rock:
Try this,
1.After you pumped the correct air pressure, do not drive off
2. Go to I-drive menu, Vehicle Setting
3. Select RPA, press the controller
4. Set tire pressure, press controller
5. Select Yes, press controller
6. Drive off
Many thanks to Bro Jerman for your guide... I succeded kill the warning light ..!!
Jerman;697262 said:
Try this,
3. Select RDA, press the controller
6. Drive off
I dun think e60 have the tyre pressure sensors in the wheel..... it only has flat tyre monitoring..... difference in rotation will trigger a flat... just reset the i drive and it should be ok.
