rafamr;490723 said:Mr Jarance, morning!
I noticed lately my left side mirror didnt tilted down when reversing.. what are the posibility failure and what should i check first?
rafamr;490944 said:ahaa... thks jarance n bimmerholic
Its all because of just using this e39 for the pass 1 month! Bimmerholic is correct! the mirror selection must always on the right side..
rafamr;497346 said:Calling Mr Jarance & Bimmerholic,
I noticed reading on the meter abt outside temperature always showing ' - 40 '.. isit because of the outside temperature sensor kaput already and if so, where its located and can we replace it by DIY?
johnj;498643 said:if the outer temperature sensor is defective and it shows -40, your aircond will go haywire during rainy season!!
bimmerholic;498640 said:I've got a feeling after replacing the radiator, the bleeding process was not done properly and there may have been some trap air still inside the cooling system. Thus when you were blasting down memory lanes, the air would have expanded so much that it blew the expansion tank beyond expansion. Just a theory...
