Kim1980
New Member
- Oct 22, 2014
- 44
So I saw some members are using the tool, think I will share some info.
LCM Options:
To enable or disable the annoying DRL:
-select “coding data”
-toggle the options for “running lights”
ZKE Options:
To do any of the functions in the ZKE section:
- select “Coding data”
To activate the alarm optics without having a physical alarm:
-check DWA
-check the options with “optics”
Note: If you have bits and pieces of the OEM alarm, you may enable those options
To activate an OEM alarm:
-check DWA
-check DWA interior sensor
-uncheck DWA interior sensor, rear (unless you have a convertible which has a front and rear interior sensor)
-check DWA tilt alarm sensor
-check the options with “optics” and “acoustics”
Note: you must have all 3 (4 for convertibles) pieces to the alarm otherwise your car will throw a code. e.g. you have the siren and motion sensor but no tilt; your DWA will show a fault and will not arm. Siren will still go off if doors are breached.
To enable remote closing windows:
-default “Opening (remote control)” is checked and “Locking (remote control)” is unchecked
-check “Locking (remote control)” to enable closing with remote
Note: the lock button closes and unlock opens the windows upon holding of the key
To enable one click to unlock all doors:
-default “Selective” is checked. This allows one click of the unlock button of the remote to unlock the driver’s door. A second click unlocks remainder passenger doors
-check “No” to unlock all doors with one press of the unlock button
To change the tilt of the passenger mirror when in reverse:
-default “Memory” is unchecked
-set mirror switch to passenger, the mirror will tilt to your personal position.
- Set your position, have switch on passenger side, and adjust your mirror while in reverse gear.
Note: if ”Memory” is checked mirror switch must be set to passenger for option to work.
Switching to driver will disable the auto-tilt.
Note: if ”Memory” is unchecked mirror switch must be set to driver for tilt to work (by default it tilts to the maximum amount). Switching to passenger will disable the auto-tilt.
EWS Options:
To check the number of keys you have used:
-select key status
-you may also disable keys if you lost them from this menu as well
Note as you can see, I have two keys out there in the world from the previous owner as I only own two of them
To view live data:
-select live data
To DISABLE the clutch switch:
-select “Coding data”
-select “Settings and manufacture settings”
-select Manual transmission
Note: only for manuals
Note: this allows you to start the car without having to depress the clutch
SRSOptions:
To view live data about your airbags:
-select live data
To DISABLE seat occupancy sensor:
-select “Equipment”
-uncheck “Seat occupancy recognition”
Note: I have not tired this as I do not need to nor have I installed aftermarket bucket seats
To DISABLE seat belt light:
-select “Equipment”
-uncheck “Seat-belt buckle switch”
Note: I haven’t tried this myself as I always wear a seat-belt nor have a race harness
IKE Options:
In the IKE menu you can change items such as service intervals frequency (i.e. km/mi until next service), etc
Got my scanner from here, installed on windows 7 64bit, had it for 2 years, used many times. It works just fine.
LCM Options:
ZKE Options:
-check DWA
-check DWA
EWS Options:
-select key status
To view live data:
-select live data
SRSOptions:
-select live data
-select “Equipment”
-select “Equipment”
IKE Options:
