hi all
zamali7
i'am zam from senawang, driving e46ci's a year already after my lovely e36 crashed. need some info with my e46.. feel like the problem are coming, need xperts to advise.. thanks.
Hellraiser;462378 said:
what sorta problems?
a lot maa..
- LED type rear light left side kaput
- eagle eyes left side also
- front absorbers out
- oil engine every 1-2month need to refill
- gear shifting some times jerking
a lot of warning light in panel maa..
zamali7;463328 said:
a lot maa..
- LED type rear light left side kaput - small problem. just get it replaced
- eagle eyes left side also - small problem. just get it replaced
- front absorbers out - small problem. just get it replaced
- oil engine every 1-2month need to refill - is there a leak somewhere? get it done.
- gear shifting some times jerking - maybe gear box problem.
i really don't see any real problem with your car other than the suspected gearbox issue. i mean, surely you don't expect the front absorbers and the eagle eyes to last forever do you? what about your tyres? do they last forever too?
i also suspect that there could be a leak somewhere with your engine but then again it could be worse. hard to say unless you take it to the mechanic who knows what to do with a bmw.
solution is simple for the first 4 problems. spend some money and your problems are solved. however, you may have a major issue with the gearbox. now that is what i call a big problem...!
