Z Series
Hesitation on cold start
<blockquote data-quote="fugowitz" data-source="post: 304826" data-attributes="member: 7492"><p>Greetings gcarch.</p><p></p><p>I read somewhere that the vanos seal failure may not necessarily be detected by fault codes (due to symptoms at start-up & at low RPM). After dismantling the vanos unit, turn it upside-down in fast repetition. If you could feel the internal piston/valve moving up & down, then the seal has definitely failed. Hope you could share your experience after the seal change. (Also, could you share with me the labour cost in changing the seal…..cause I also plan to do a seal change in due course). BTW, you may need to change the top gasket plus the vanos gasket in the process. Best of luck.</p></blockquote><p></p>
[QUOTE="fugowitz, post: 304826, member: 7492"] Greetings gcarch. I read somewhere that the vanos seal failure may not necessarily be detected by fault codes (due to symptoms at start-up & at low RPM). After dismantling the vanos unit, turn it upside-down in fast repetition. If you could feel the internal piston/valve moving up & down, then the seal has definitely failed. Hope you could share your experience after the seal change. (Also, could you share with me the labour cost in changing the seal…..cause I also plan to do a seal change in due course). BTW, you may need to change the top gasket plus the vanos gasket in the process. Best of luck. [/QUOTE]
Z Series
