Bro i was in the same boat as you and my research has come out with a few options
1. the components you stated is expensive a cheaper alternative is Audio control the model is LC6i i was using this for exactly 1 month and i traded it in cause i wanted to upgrade my whole ice setup and the OEM head unit was holding me back. I recommend the LC6i as it is not so costly and serve its purpose with 6 line output. This option is the best if you just want a minimal upgrade to your ICE
2. there is alternative aftermarket HU that comes with adapters so that you don't have to lose your steering control brands that come to mind is Alpine, I am currently using Blaupunkt Memphis mp-66 the adapter for the steering control is additional extra. I went for this option and i have no regrets.
If you need more help PM and i will answer any questions and also my installer if you need to buy any of the above mentioned products.
