3 Series
E46
Help!! E46 320ci problem....dont know whats wrong
<blockquote data-quote="JOKER" data-source="post: 317613" data-attributes="member: 11782"><p>better check the brake light signal to the EGS.., i detect mine was not respond.., find-out it was missing link to EGS in the X69 socket., with-out brake signal... the EGS did not respond to what it should do, this cause the car still run with driving gear and poor stopping power!!!!, this was a con; and will cause the brake disc and PAD worn faster... surplus horrible nightmare will happen in the transmission BOX!!!</p></blockquote><p></p>
[QUOTE="JOKER, post: 317613, member: 11782"] better check the brake light signal to the EGS.., i detect mine was not respond.., find-out it was missing link to EGS in the X69 socket., with-out brake signal... the EGS did not respond to what it should do, this cause the car still run with driving gear and poor stopping power!!!!, this was a con; and will cause the brake disc and PAD worn faster... surplus horrible nightmare will happen in the transmission BOX!!! [/QUOTE]
3 Series
E46
