headlight brightness
Replay
Bro's, my headlight seems to be a tad dim, its the post face lift xenon and I've compared it to a E60 and a E90, both seems to outshine the E39 xenon. Is this normal or is my ballast kaputzky?
champion;531137 said:
Hi Bro, i am also having dull shine. Probably need to change to a better bulb/ballast.
For more info - pls go thru this thread if you havent done so, http://www.bmwclubmalaysia.com/forums/showthread.php?t=29774
Btw, collected your vanos seal ?
Open your hood and hold the bulb socket and check is it is shaking. It's not your ballast. It is your headlight adjusters i am sure they are broken and your light are drooping down thats why it not bright.
http://bmwclubmalaysia.com/forums/showthread.php?t=34578
Bimmer73, I've used cable ties to temporary prop up the beam and its still looking a tad dim. going to consider replacing the stock halogen spotlights with HID's.
bimmer73;531643 said:
Replay
where did you install your vanos seals
Installed at Optimum Kayu Ara...took a couple of hours for the job. Changed a number of hoses in the process.
I'm on HIDs and the beam is brighter than the normal halogens but still not as bright, I think need to change the headlamps, the projector maybe degraded....The only way to try is if I cud get one side of new lamp to try it out...
Replay
hai harbhajan from raub,i want to change my headlight adusters ,can u pls help me how much is the cost,
mine is e39 528
do it your self, $110. that is d cost of new face lift adjuster, ask ppl to do, ranging from $300 to $500 i think.
Adjusters plus labor is RM500 per car. guarantee wont break if you hit pot hole. One headlamp is RM250
Bro, that's cheap. I paid RM600 at BM Wong, USJ1 Subang Jaya.
bimmer73;536809 said:
yeah cos i do it.....hehehe and i don't remove lense.
can u do that without removing the light cover? wow... I have replaced the adjuster of both headlamp, the 1st took me 4-5 hours labour, 2nd one took less than 1.5 hours.
yup. 1 head lamp 45 minutes
bimmer73 is right, unless the adjusters are still fine..sharing with my personal experience.
THanks bro for doing my lights. Money well spent. Adjusters good and with my HID now, good shine and distance.
