Handbrake light always on
suntze
Hi guys, my handbrake light is always on eventhough I have disenggage the handbrake.What's wrong with my car?Thanks a bunch in advance
if its a proton, 100% brake oil not enough, topup abit only the light will be gone
*smack forehead*
E46
brake oil u can press the Onboard computer n check one la
Originally posted by leakwoon@Jun 9 2006, 10:37 AM
*smack forehead*
E46
Really? I thought the E46 OBC only gives info on av. speed, av. fuel consumption, distance-to-empty-tank, outside ground temperature and clock.
sorry hijack abit , but same problem like the topic starter ...
i m having the same exprerience also lar , but when i corner to the left the light gone , then go back stright on again ....
Maybe your brake fluid level sensor needs to be changed. Or, try topping up your brake fluid and see what happens.
yeah, try topping up abit. but if its at max level, i think something else is wrong
*smack forehead*
E46
bro, ours 318i got such function? even avg. speed, avg. fc., temperature also dun have mar
issit the parking light.....For E36...usually due to the limit switch under the hand brake console. Try opening the console n search for this switch...usually offset and causes the intermittent parking light.
regards
bro tikus yr is ckd 318 right, dont have the function 325 got lah, only jap spec 318 have all the function, avr speed, temp, etc
OICCCCCCCCC, thanks for your info, y CKD so paria one
