5 Series
E39
fuel level indicator koyak
<blockquote data-quote="moots" data-source="post: 480307" data-attributes="member: 219"><p>thanks jarance.yes i did chk the rubber mount and it's good and the reason why the wire snapped was becos it was not secured properly at the last bit and the sloshing of fuel caused the wire to move about and eventually broke,i suspect the last time the fuel pump was repalced ('07 as told by PO) the wire was not secured properly.</p></blockquote><p></p>
[QUOTE="moots, post: 480307, member: 219"] thanks jarance.yes i did chk the rubber mount and it's good and the reason why the wire snapped was becos it was not secured properly at the last bit and the sloshing of fuel caused the wire to move about and eventually broke,i suspect the last time the fuel pump was repalced ('07 as told by PO) the wire was not secured properly. [/QUOTE]
5 Series
E39
