3 Series
E46
friend need advice.
<blockquote data-quote="Iceduke" data-source="post: 639198" data-attributes="member: 3721"><p>allow me to give my 2sen...I think this thud is normal for older cars, I have the same as well when the car slows to a stop. The thud is normally heard at the rear. This I attribute to the differential or rear subframe mountings that are past its age. If the sound is from the rear then its the 4 subframe bushes. Its a common wear item on e46s. </p><p></p><p>Hope this helps.</p></blockquote><p></p>
[QUOTE="Iceduke, post: 639198, member: 3721"] allow me to give my 2sen...I think this thud is normal for older cars, I have the same as well when the car slows to a stop. The thud is normally heard at the rear. This I attribute to the differential or rear subframe mountings that are past its age. If the sound is from the rear then its the 4 subframe bushes. Its a common wear item on e46s. Hope this helps. [/QUOTE]
3 Series
E46
friend need advice.
