f10 electronic damper control can be disabled?
paultantk
http://f10.5post.com/forums/showthread.php?t=568266Features:- 1 = Front and rear height adjustable by threaded shock bodies- 37 = Vehicles equipped with electronic damper control: Electronic damper control needs to be disabled. Disable modules available through KW. Please check KW accessories list.- 67 = For vehicles equipped with electronic damping DCC, the electronic damping control needs to be deactivated. Deactivation kit part no. 68510141Variant 3 - Race technology for the roadwith adjustable compression & rebound dampeningThe new Variant 3 ist state-of-the-art technology for the skilled and experienced driver. The separate and independet compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed-range, while the highspeed set-up, so decisive for driving comfort, has been pre set by our engineers.- Independently adjustable damping technology - rebound and compression damping- 'inox-line' stainless steel technology- Individual height adjustment- TÜV-tested adjustment parameters- High quality components for long life- Comprohensive documentation for ease of use
Our f 10 has the option of different ride quality. That is with the original absorber, spring etc. however, when you change after market suspension for lower ride height, better handling etc. you will loss that option because of different setting.however, kw version 3, does have the option use back the original I drive setting although it is not yet ready for f 10.currently it is available with some vw DCC like golf and sccirro.
I was very tempted to get the KW V3 but being close to RM 10K installed, had to reconsider...
