E90 Rims on E39
GHS
Happy CNY! :)Would like to know if E90 17" rims can fit on the E39?A quick search on Google reveals the following:1) PCD: should be the same - 5 x 120?2) Offset: E90 ori offset is typically 34 - 37, E39 15 - 25. Using spacers should make the E90 rims fit on the E39 and clear the brakes?3) Centre Bore: E90 - 72.6; E39 - 74.1. The smaller centre bore of the E90 should fit on the bigger E39, no?If it doesn't fit, can something be done so that it fits? Appreciate the advise. Thanks :top:
Center bore is critical on fast car.. it helps holding the wheel central rather than just depending on the lugs... try to get one that fits the central bore size as well.
