5 Series
E60, E61
E60 parts & maintenance
<blockquote data-quote="Thomas Anderson" data-source="post: 757403" data-attributes="member: 66425"><p>You can install wheel spacers to <a href="https://www.bonoss.com/will-wheel-spacers-fix-rubbing-xjm209.html" target="_blank">avoid the rubbing</a> problem, the role of wheel spacers is to increase the backspacing to adjust the offset value.</p></blockquote><p></p>
[QUOTE="Thomas Anderson, post: 757403, member: 66425"] You can install wheel spacers to [URL='https://www.bonoss.com/will-wheel-spacers-fix-rubbing-xjm209.html']avoid the rubbing[/URL] problem, the role of wheel spacers is to increase the backspacing to adjust the offset value. [/QUOTE]
5 Series
E60, E61
