i recently noticed some oil leak on the floor.. took for a check and it was engine oil leaking from the oil filter housing...i understand that there is a rubber seal at the interface between the oil filter housing and the engine block..will changing this suffice.i was advised to change the whole oil filter housing at a cost of RM1550.00 (part only) as replacing the seal would not guarantee that it will not leak soon.anyone out there with this similar experience..regards
